rstoltenberg1
- Joined
- May 29, 2014
- Messages
- 8
Hello,
After my last radio quit, I got a used 7160 from a friend. He showed me it worked before it was removed from his truck. I goto put it in mine, and it won't power up. I think Ignition sense is active. It turned on and off with the key when he showed me it worked. I was pretty sure I had it wired correctly when I installed it in my truck, but it refuses to power on. I didnt get the Yellow wire from him because he was going to use it for his 7360. But I ran a wire from the yellow pin in the connector, to a 12v switched source and no go. After some research, I think it is pin 2 in the connector, which is pink. But it was still a no-go. Anyone have a suggestion? Thanks
Robert
Robert
