Hello all,
I am have a TX issue with a Kenwood TK-7360 Commercial radio (VHF). The issue is that I can not TX on the first two channels in the radio, or it is actually TX'ing, however I do not get any feed back from the repeaters. I have the red LED active when it hit the PTT on the mic, so I really do believe that it is really TX'ing. The repeaters are commercial. They are for Fire and EMS specifically, and yes, I am affiliated with two volunteer departments that use the repeaters as a primary source of being toned out on and as backup to TX dispatch. The two repeaters that I can not hit on this Kenwood, I am able to on any other mobile or HT. I have confirmed TX, RX freqs, and the DCS tones that are used. The first channel does have the 2-Tone signalling option for a set of two QCII tones to be decoded. I can still monitor these two repeaters just fine with out any QC tones being encoded from dispatch (like having an open pager). I can hit my local EMA repeater that is also commercial just fine, I can TX, RX it with out issue, and its the same brand repeater as the first two. So I can't tell if its the radio, the software I am using or if its just a glitch, or a specific setting that I need to set up. The software I am using is the KPG-135D version 2.11 I also use this radio for Amateur use without any issue. It just the first two channels in the radio that I can not TX on. Any ideals. You can reply to here or email me at kd9bkh@gmail.com
