JVCKENWOOD Corporation announces the release of its technologically advanced NEXEDGE
NX-3000 Series Multi-Protocol Radios. Supporting both NXDN® and DMR Tier II digital protocols
as well as mixed digital & FM analog operation, these radios are versatile and powerful
performers for a broad range of enterprise and operation critical applications. Engineered to
be compact and durable, the portables are packed with convenient features like Bluetooth®,
built-in GPS and world renowned KENWOOD audio with Active Noise Reduction (ANR). Two
mobile and three portable models are available with options including full keypad with LCD,
standard keypad with LCD and a large 4-way D-pad, and basic model without LCD or keypad.
Software; LMC ACCOUNTS required for licensed options. LMC for software does not need account activation.
KPG-D3NK List 155.00
NX-3220K VHF (136-174MHz), 5W, 64 CH, Non LCD and Keypad $470.00
NX-3220K2 VHF (136-174MHz), 5W, 260CH, LCD and D-pad / 4Key $553.50
NX-3220K3 VHF (136-174MHz), 5W, 260CH, LCD and D-pad / 12key $603.50
NX-3320K UHF (400-520MHz), 5W, 64 CH, Non LCD and Non Keypad $470.00
NX-3320K2 UHF (400-520MHz), 5W, 260CH, LCD and D-pad / 4Key $553.50
NX-3320K3 UHF (400-520MHz), 5W, 260CH, LCD and D-pad / 12key $603.50
NX-3720HGK VHF (136-174MHz), 50W, 512 CH, 128 Zones $684.00
NX-3820HGK UHF (450 - 520MHz), 45W, 512 CH, 128 Zones $684.00
NX-3820HGK2 UHF (400 - 470MHz), 45W, 512 CH, 128 Zones $684.00
OPTIONS - LIST PRICE
KWD-3000CH License Key for 1000 Channel Expansion $160.00
KWD-3001FP License Key for Front Panel Programming $125.00
KWD-3002BT License Key for Bluetooth Serial Port Profile $35.00
KWD-3501TR License Key for Digital Trunking (Includes NXDN Type-C and Type-C Gen2) $41.70
KWD-3502EE License Key for DMR ARC4 Enhanced Encryption $40.00
KWD-3503AE License Key for AES/DES Encryption $450.00
KWD-3504RC License Key for Remote Control by Subscriber Unit $40.00
Notes
• NX-3000 comes with Analog and Digital Conventional (both NXDN & DMR) as a factory default. NXDN
conventional or DMR conventional can be programmed to the radio via FPU with no additional charge and the choice is not permanent.
• Additional software license KWD-3501TR is required for Digital Trunking operation. Digital Trunking currently covers both NXDN Type-C Trunking and NXDN Gen2 Trunking.
• Majority of audio accessories, antennas, batteries, and chargers from NX-220/320/720/820 Series can be used with NX-3000 Series. However, there are some legacy audio accessories that are incompatible with TDMA(DMR) operation.
• 2-PIN Accessory Cover is mandatory for waterproof and immersion warranty.
• Intrinsically Safe Option will be available 3Q-2017.
CONTACT YOUR LOCAL DEALER FOR MORE INFORMATION
Notes
