Nx 300 k2 programming issues
wconn
I have purchased a NX 300 K2 from ebay. Had UNPROGRAMMED on the screen. I have attempted multiple versions of KPG 111 to program this radio. It will take the programming but when you go through the channels they are all mixed up and some are missing or others may repeat themselves. If you have more than one zone, one channel may be in that zone but most channels will not show up. Figured it could be a Firmware issue. Any help would be appreciated.
kd4efm
Florida
Channel knob or flex bad
Sent from my SM-G935P using Tapatalk
wconn
Alright. I programmed my Up key for channel up. This seems to keep everything in check. All other buttons appear to work as programmed. So looks like the knob or band is the issue. Thanks ....Any idea on what this may cost to be replaced?
kd4efm
Florida
If have to look it up, you good with a solder iron?
wconn
I'm so, so. If it is any surface mount stuff that is out of the question. My eyes don't work as well as they used to.
