Yes. Once you do the Software cancellation you use the original key on the next computer. This is for the dealer programming software only. For radio feature licenses e.x. DMR you will also need an account key and you need one per computer. At least I haven’t figured out how to cancel the account and move to another computer to add additional licenses.
Okay, the JKEFS (software key) never changes when activating or deactivating on a PC.
ANY PC with LMC without an account activation file CAN BE USED (however, only 1 PC at a time)
Here is a run down on what the files are and mean:
LMC - in order to push RADIO FEATURE LICENSES, you must have an account activation (JKEFA)
The jkefa file will tell you how many "seats <pc's>" it can be activated on.
KWD-ACT_____NUM0005_0001_xxxxxx_2015-06-26.jkefa
*THIS CANNOT BE CANCELED AND MOVED FROM PC TO PC, THE MACHINE ID AND THAT
ACTIVATION FILE ARE HARD CODED TO A MASTER SERVER.
The only way you can add to the account seats, you have to have the ORIGINAL KENWOOD EMAIL,
and the dealer submits a request to kwd tech support to increase the number of seats. It does NOT
happen over night! It is best to plan ahead, order 5 seats and save the email / file for future reasons.
* PS, it is a moot point to worry about the license keys because once you use a feature key, after 72 hours
it becomes locked to that radio. Just order a new activation file and move on. (IMOW)
What it means:
KWD-ACT - this is an account activation file
NUM00## means number of pc's
XXXXX is the invoice number followed the date it was created.
Defining the software:
Software
DEALER_KPG-D1N_W_NUM0001_0002_SVCxxx_2016-07-14.jkefs
DEALER_KPG-D2N_K_NUM0001_0001_xxxxxx_2016-12-19.jkefs
DEALER_KPG-D3N_K_NUM0001_0001_xxxxxx_2017-11-07.jkefs
Dealer = level of access
KPG-D#N_ - Software key is for: D1, D2, D3, D5
W/K - This tells you the program is Wide Band or "K" standard / narrow band
NUM0001_00## - this tells how many license KEYS are in this sequence (1 of x)
xxxxxx / SVC - this is a sequence number / order number
Date, date is was keyed into the system.
This can be moved from PC to PC using the authenticate, software, process of the LMC.
You DO NOT need an account activation file to run just the software.
WIDE BAND LICENSES, if you do not deactivate it from the LMC while a known hard drive crash
IS POSSIBLE / HAPPENING, YOU LOSE THE WIDE BAND KEY FOR LIFE. It will not be
regenerated, or anything else from Kenwood. IT IS A ONE SHOT KEY. Order another wide band
key if your hard drive tanks. Can't make it any clear than that. (not my word, but kenwoods)
