kenwoodgeek
I'm dealing with another school bus radio that doesn't seem to be working correctly.
The radio keeps its squelch open pretty much constantly, as if it is set to 0, when it is actually set at 5.
With the microphone in the clip, the receive LED stays illuminated, and when you take it off, you get constant static between transmissions. Very seldom will the light go off and there will be no signal on the radio.
I am programming all the bus radios with the same programming file (FleetSync IDs are different), and none of the other radios are doing it.
Any suggestions? Bad radio?
I can send the KPG-111D programming file, if needed.
Thanks in advance!
Thanks in advance!
