NXR-5700 Programming Trouble
Motoflightmedic
Ø
Got a new NXR 5700 in today, have the software installed on my CF 30 running widows 7, ordered the Kenwood usb programming cable. plugged the repeater into the pc via the kenwood cable, the driver installed. but when i go to Setup>Communications port there is not an option to select USB on com ports and LAN ip addresses nothing about USB....
kd4efm
Florida
Check device manger?
What cable did you get?
Did you try using just a USB A to USB B
Cable?
If you used a kpg46xm, and the mic jack, that's incorrect.
Sent from my SM-G935P using Tapatalk
Motoflightmedic
Ø
I had not, i went to device manager and found it and it was labeled com 27, changed to com 27 and wow it worked. now i feel like a complete idiot.
Thanks for the help.
kd4efm
Florida
Copy that. Good job.
