TK-730/830 remote mount not powering on
OFD-14-109
Otsego, MI USA
Hello all I have acquired a tk-730/830 dual band radio, I have no experience working with kenwood radios but do have experience with the big M’s. I can not get the radio to turn on when I press the power on the KCH-4 remote head I get no response from either radio. I have the radios connected to my 12V power supply in order to program them before installation any help or hints would be appreciated I have included some pics of how I have the system connected.
Arizona
Perhaps they are programmed to ignition sense. Meaning the control head may have to see 12v before the radios will turn on. This is used a lot in public safety vehicles for the radio(s) to turn on or off with the key rather than a push of a button. Google the service manual for the pinout on the radio and see if that helps your radios turn on.
OFD-14-109
Otsego, MI USA
I have looked at the radios the TK-730 has the mod for the ignition sense done to it the 830 does not. I have power going to the black wire on the 15pin connector and it still will not power on. Is it possible that it needs 12v supplied to the control head accessory connector as well as the radio 15 pin connector. I had to move the black wire in that 15pin connector as it was originally in hole #5 which is the mic input/output could that have something to do with it?
AD0TY
Indiana
Make sure the ground wires are connected on the head and both decks. We've had some 730s and 790s do weird stuff when the ground breaks off or comes loose.
I don't have service manuals for those, but it's very common for their to be a fuse on the inside of the radio soon after the power enters it. It can commonly be a "pico fuse" that will look like a green resistor. Could be at one point someone hooked it up backwards, popped the fuse and just sold it rather than fixing it.
OFD-14-109
Otsego, MI USA
Thank you all for the info by chance does anyone have a pinout for the control head because I have no ground wire for the control head. I reviewed from a person that bought a government lot auction so I may not have all required wire harnesses and I am completely new to kenwood radios. I have looked at the service manual and perhaps I overlooked to control head accessory port pinout. Thanks again!
OFD-14-109
Otsego, MI USA
Ok so figured out the powering on issue, radio was modded for ignition sense at the control head not the RF deck. Radio powers up now I have a couple more questions with the ignition sense mod done can you not over-ride it and turn the radio off with power button on the control head? Also could you explain to me what the two mods I have circle in the picture are? I have been trying to search the internet for the dual band mods to see if they are part of that but I'm suspecting it is not as the wires are coming from the 15 pin accessory connector. Last does anyone have the mollex connector psrt number for the 6 pin port on the back of the control head?
