NOT A MAJOR DEAL BREAKER, BUT TAKE PLEASE SEE MY NOTES.
Version effected 1.20 KPG-D3NK
RESULTS: ENCRYPTION ISSUE
BUG: PORTABLES CAN'T BE ASSIGNED A KEY ID FOR STANDARD ENCRYPTION INFORMATION
OR USED WITH OTHER EXISTING RADIOS WITH KEY ID KEYS GREATER THAN "0", TRUNKING OR
CONVENTIONAL.
RESULTS: NX-3720/3820 MOBILES CAN BE ASSIGNED KEY ID, WHERE-AS PORTABLES CAN NOT.
THE RESULTING ISSUE IS PORTABLES RETAIN KEY ID "0" AND THE KEY DATA THAT IS ENTERED.
IF THE MOBILE KEY ID IS ANYTHING OTHER THAN "0" , THE PORTABLE WILL NOT BE DECODED.
TESTED RADIOS: NX-5300, NX-3320K2, NX-3820HGK, NX-5800, ICOM 6021D, NX-300, NX320
TEST CODE: KEY DATA 12345, KEY ID 0, TG 1
TEST CODE: KEY DATA 11223, KEY ID 1, TG 1 (2 SEPERATE PROGRAM CODE PLUGS)
TEST 1: 464.550, RAN 1 VNFM, TG 1 GROUP CALL SET.
TEST 2: TYPE C TRUNKING SYSTEM, GROUP CALL 1
TEST 1, DATA 12345, DECODES CORRECTLY ACROSS ALL RADIOS
TEST 2. DATA 11223, ALL BUT THE NX-3320K2 DECODE, NX-3320K2 CAN TALK TO EACH OTHER
BUT ALL OTHER DEVICES DO NOT DECODE RECEIVED SIGNALS
SIMPLE FIX: PROGRAM PORTABLE KEY DATA AND MOBILE KEY DATA AND USE KEY ID "0" TO
ENABLE PROPER ENCRYPTION DECODE BETWEEN PORTABLES AND MOBILES, AND OTHER NXDN RADIOS UNTIL REVISED SOFTWARE IS MADE AVAILABLE.
TESTED: 01-12-18 EFM
SUBMITTED TO KENWOOD, 01-12-18, FOR TESTING AND REVIEW.
ANY RESULTS FROM OTHERS WELCOMED IF FOUND TO BE DIFFERENT FROM BENCH TEST.
EVANS
CONVENTIONAL.
EVANS
