Kenwood TK-5210 Programming Cable
Metrofire31
Auburn-Opelika, AL
I'm having a problem programming my TK-5210 that I don't understand. I'm using the proper programming cable for this model radio, and yet, I can't seem to open the COMPORT. My laptop has only one USB port but the software isn't detecting any of them (it's usually COMPORT 3). I've checked - and double-checked - connections on both ends but still no open COMPORT. And yes, I have the radio turned on.
Any suggestions?
Metrofire31
Franklin, NC
WQIT636 (GMRS)
MSS-Dave
Generally Central Florida
Any suggestions?
Metrofire31
Franklin, NC
WQIT636 (GMRS)
Did you install the driver for the correct platform you are using IE 32-bit or 64-bit windows? The USB cable generally pulls a comport above 8 in my experience. The driver generally isn't included in Kenwood software.
Project25_MASTR
Millennial Graying OBT Guy
Texas
Are you using a native USB cable or a serial cable with RS232-USB adapter? A lot of the aftermarket cables use counterfeit chipsets that don't play nicely with Windows. Main reason why I tend to stick to serial cables and then a solid, known good RS232 adapter since most IT departments don't see a reason for a serial port these days...
Metrofire31
Auburn-Opelika, AL
I've had this cable (aftermarket cable with USB connector) for several years and don't recall ever installing a driver. I prefer RS232 cables also so may look to ordering one for this radio. Thanks for the tips - I appreciate you both.
Metrofire31
