TKR 750 users
jcromin
Anderson, Alabama
Would like to hear from users who use the TKR 750 Repeater with a external controller in duplex mode. I cant get the the DCS codes to work thru external controller. The transmitter will key with or without a DCS code.
ramal121
Lots and lots of watts
Calif Whine Country
For the external controller, are you using one or two logic lines for a received signal indicator?
If just one then the programmable pin needs to be set as TOR which only asserts itself when QT/DQT is present (COR is active on any carrier present).
If you use two logic lines for receive (TOR and COR) the controller needs to be programmed to "AND" these two together to utilize QT/DQT.
