Firmware release: nx-3000 1.30 / NX-5000 2.50
kd4efm
Florida
JVCKENWOOD announces the release of the NEXEDGE® NX-5000 Series Firmware Version 2.50 and NX-3000 Series
Firmware Version 1.30. This firmware release includes the new Digital Encode / Decode Format, Task Request, and
several feature enhancements.
NX-5000 / 3000 : NXDN & DMR Updates
Digital Encode / Decode Format*
Digital Encode / Decode Format is a new function which allows dealers to program the way the radio operates by
combining an available list of control commands. Through applicable the FPU, the radio may be programmed for
unique radio operation that suits specific needs and use cases.
List of available commands:
Alert, Beep, LED control AUX port control
Backlight control Channel control
Delay time Scan control
Repeat command Horn Alert control
Display control ID comparison
Key local control
*Please refer to the application notes from your Dealer
Task Request (NXlink / HotSoS Solution)
Task Request is a new function that allows operators to assign tasks to a group or individual through task messaging.
With this new feature, field users are able to respond to assigned tasks and update status to operators accordingly.
The Task Request message contains a reference number for each individual tasks to be tracked, replies to be
linked, and managed throughout until its completion.
This feature is a complementary update for NX-5000 / 3000 subscribers which are to be used with the
NXlink solution
package. Please contact Systems Group for details and availability.
Short Data Message
Character limitation for Short Data Message is expanded to 314 from 100 characters.
Over the Air Alias
GPS Report with Voice
GPS Combination
Hot Mic
Allows the use of input audio from mobile microphone and external mic input simultaneously.
Tactical Zone Scan
Off-hook Scan Improvement
NX-5000 Series Updates
Save GPS Data
New PF Key command allows user to store current GPS position and time to microSD card.
SD Card Selection
Allows you to choose which SD card to be used for data storage in Multi-RF Deck configuration.
NX-3000 Series Updates
KWD-3505DE DES Option
The new DES option license is available for NX-3000 series. The license can be authenticated by KPT-300LMC and
encryption key can be loaded by KPG-AE1K or KPG-DE1K, software key loaders.
Single Head Remote Deck Configuration
Along with the introduction of new KRK-18HM/KRK-19BM Remote Kit, the new firmware and FPU is ready to configure
remote control head configuration for NX-3000 series mobile.
kd4efm
Florida
another thing.....
software speed still the same.
Sorry gang, but, this was brought up at iwce orlando!
Also update KFL and your KPT300
otobmark
NC
I've successfully used a win7 virtual machine on parallels and macbook. Since updating VR to Win10 I have found the UART driver (used w/ KPG-36X cable) to be unstable/unusable. My desktop is still on Win7 so not sure if parallels issue or just a win10 issue. Anyone else running win10 with this cable?
KK6ZTE
California
Yes, using Windows 10 and no issues.
Scan works now in Tactical zone but still no analog channels from non-analog systems. Channel Information doesn't work on non-analog systems either.
