J700 - 25pin connector TK-7150 Mobile
1 NC Non connection.
2 RXD2 * Serial data input 2. RS-232C level. Input voltage
range = ±30V max. L ≤ 0.4V, H ≥ 2.4V. Zi ≥ 5kΩ
3 TXD2 * Serial data output 2. RS-232C level.
L ≤ –5V, H ≥ 5V/3kΩ load. Zo ≤ 2kΩ
4 AO3 Auxiliary output 3 (Programmable). Active low
open collector (100mA max.) (Default none). L ≤ 0.3V
5 DI Data signal input (Capacitor-coupled). Z ≥ 10kΩ
6 MI2 External MIC input (Capacitor-coupled). Z = 600Ω
7 E Ground.
8 AO2 Auxiliary output 2 (Programmable). Active low
with 10kΩ pull-up to 5V (100mA max.) (Default
none). L ≤ 0.3V, H ≥ 4.8V
9 TXD3 ** Serial data output 3.
L ≤ 0.7V, H ≥ 4.2V/25kΩ load. Zo ≤ 1kΩ
10 RXD3 ** Serial data input 3.
Input voltage range = +5/0 max. L ≤ 0.8V, H ≥ 4.2V.
11 E Ground.
12 AI4 Auxiliary input 4 (Programmable). Active low
with 47kΩ pull-up to 5V (Default none).
L ≤ 0.8V, H ≥ 2.5V
13 AI2 Auxiliary input 2 (Programmable). Active low
L ≤ 0.8V, H ≥ 2.5V
14 SB Power output after power switch. 13.6V±15%,
1.1A max. at 25°C, 0.8A max. at 60°C
15 TXS TX sense signal output. Active high with 10kΩ
pull-up to 5V. L ≤ 0.3V, H ≥ 4.8V
16 HR1 Horn alert signal output 1. 1A max.
17 AFO Filtered audio output (DC-coupled). Zo ≤ 1KΩ
PA : MIC signal output. 0.65Vp-p typ. (1kHz/5mV input)
RX : RX low level output. Wide : 1.3Vp-p typ.,
Narrow : 1.1Vp-p typ. (Standard modulation)
18 E Ground.
19 DEO Detected signal output (Capacitor-coupled).
20 AO1 Auxiliary output 1 (Programmable). Active low
21 AI1 Auxiliary input 1 (Programmable). Active low
L ≤ 0.8V, H ≥ 2.5V
22 AO4 Auxiliary output 4 (Programmable). Active low
L ≤ 0.3V
23 HR2 Horn alert signal output 2. 1A max. (Default ground)
24 AI3 Auxiliary input 3 (Programmable). Active low
L ≤ 0.8V, H ≥ 2.5V
25 ME MIC ground.
