NX-5000 encryption compatibility
KG4JCF
Levy County, Florida
Has anyone tested the encryption compatibility between the NX-5000 and Icom NXDN radios? I know the ic-f3161 and ic-f5061 has built in 15 bit encryption standard for NXDN. Does the NX-5000 series support this?
kd4efm
Florida
Yes, it works fine, i use it daily. Has to be same key id and code to work correctly
Sent from my SM-G935P using Tapatalk
