Hey yall trying to program my emergency button but can't remember how to do it. Anyone program this before that can help me out
The 2180 has mdc signaling also
Really? Mine has mdc 1200, I guess it's the option board or firmware unless it's fleetsync and they just called it mdc1200
MDC1200 on the TK-x180 line is a firmware upgrade for most radios.
You'd need to upgrade both the KPG-89 and the radio firmware to access the MDC-1200 functions.
sorry i been mix up, i ddnt notice that you need to select between Fleet or MDC if you select in the model portion and signalling. is been long time i never program the x180 anyway, the topic before is about emergency, i just focused for it, like i said is more option in fleetsyn than MDC.
sorry i been mix up, i ddnt notice that you need to select between Fleet or MDC if you select in the model portion and signalling. is been long time i never program the x180 anyway, the topic before is about emergency, i just focused for it, like i said is more option in fleetsyn than MDC,
i open topic about emergency for shutdown, but im using KAP 2 for accessories relay inside the RADIO
but i wan to know more about accessories output in the radio. with out using KAP 2, maybe theres a programming that can activate the accessories at the back of the radio.
So he is better off using fleetsync over the mdc on the 2180 with emergency and stun and such?
