How do I adjust Squelch on a Kenwood TK-380?
wp4mps
Mayaguez
Hello everyone:
Can anyone tell me where do I fing the setting to adjust the squelch on the TK-380 on the programming software?. All channels that don't have encode tone stay open all the time.
Hiding in a coffee shop.
Easiest way to do it is to program a button for squelch. Once that is done, you can press the button and adjust as needed.
I can find the specifics, but not until I get back into the shop on Wednesday. I set up a bunch of TK-390's this way a few weeks ago.
ramal121
Lots and lots of watts
Calif Whine Country
Great idea, but the rub with this series is that squelch level is not available to assign a button. The only way to set a squelch level is with programming software.
wp4mps
Mayaguez
Well it's a friends radio and I'm programming it for him. I can see in the menu where one can assign a button to squelch, but there's no more adjustment options on the software menu..
ramal121
Calif Whine Country
Perhaps you're looking at the selection for monitor carrier squelch in the button menu? That's not what you want. You need what's called Squelch Level and is not found in that model radio.
The only squelch adjustment is in the test mode section of the software and you have to have the radio connected to enter that menu section. It's easy to bump it up several points, exit and test to your satisfaction. However refrain from diddling other items in the test menu unless you know what you're doing.
