5300 model decode
pfd9100
I have a new (used) purchase 5300 model 242567G which says UHF?
I have PCC2.18.06, and 2.14
Both will read the Options on the radio but nothing else.
Boots up version 8.10.29 What PCC version do I need?
And is that 8.10.29 firmware version available for some of my other models? Looks better on the Lightning head.
AD0TY
Indiana
I'm confused because I'm pretty sure the most recent firmware for ES radios is 6.16.x, I've never heard of a firmware version of 8.x.x, that must be the DSP version or something.
pfd9100
I guess I should mark this as solved. It was a used radio I purchased. It looks to be an early VM600.
Thanks,
KD8GUA
The "5600" radios are the VM series mobiles. They use a different programming software than PCConfigure. I believe it's called Armada. I've never used it.
wa8pyr
Technischer Guru
Staff member
Lead Database Admin
Ohio
Correct, Armada. Has it's quirks but considerably easier to use than PCConfigure.
pfd9100
SOLVED
Thanks ALL for the replies, Yes it is apparently an VM600,wish I had more of these!
I ordered an interface cable and viola Armada picks it up and programs it just like the VM's in the inventory!
As usual the members of this forum jumped right in and solved another of my issues! To bad there isn't a "psychoanalysis" section!!
THANKS!
n3obl
Ø
PA
Happen to have a current cost on the cable and software?
pfd9100
cable
Just ordered the cable, $39
The software license came with my VM900 purchased so I dot really know on that.
