TK-8180 Programming Help!
calebshifflett
Hello all,
I am hoping someone can help me program a TK-8180 K UHF radio that was given to me. It looks like it is on the MPT firmware and cannot be programmed with the 89d software. I have a copy of KPG-96D that can read the "transceiver information" but I am unable to change the model on the "model information" tab as it is grayed out. I am not sure what do to at this point in time as I have no way to actually program this thing.
Thanks in advance!
The MPT functionality is controlled by the radio firmware, so you can't change it with the programming software. You'd need to update the firmware in the radio with non-MPT firmware, I believe.
I've never tried doing it, so take that as a nickel's worth of free advice.
ramal121
Lots and lots of watts
Calif Whine Country
Yea, you can replace the firmware to make it a plain Jane TK-8180 (no MPT). It is done with a firmware file and the FPRO program that should be included in the KPG-96 software. Once you do that then you'd have to acquire the KPG-89 software however to be able to program it in any fashion.
Sent from my SM-T560NU using Tapatalk
calebshifflett
This sounds like exactly what I want to do, how would i go about getting the firmware? I don't have a Kenwood dealer I can contact.
I just downloaded it online. Easy to search for it with keywords: kpg-89d download
Id provide the link, but being new here myself I dont know if cross linking is in forum policy
A cdrom can also be found to purchase off ebay or amazon
