Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > Kenwood & EF Johnson Forum
Kenwood & EF Johnson Forum - For discussion of land mobile radio products manufactured by Kenwood or EF Johnson. For discussion of Kenwood Amateur Radio Equipment, please use the Amateur Radio Equipment forum.
Old 06-30-2018, 9:30 AM
Default Encryption Keyloading a Viking Series Radio???
Has anybody keyloaded a Viking series radio??? Specifically a VP5000 or VP6000. Is there anything special that needs to be done to put it in keyloading mode and will my older key loading cable work??? My keyloader is a KVL 3000 plus.
Thanks for any help.
Old 06-30-2018, 3:51 PM
The Viking radios should automatically go into keyloading mode once they detect that a keyloader is attached to the sideport. If that's not happening, then you likely have the wrong cable.
Old 07-05-2018, 12:01 PM
cowand's Avatar
I've key loaded several VP900s with a KVL3000. Our VP900s will sense the keyloader when the cable is attached, even if the cable is not attached to the keyloader. Good luck...
