aschenavar
- Joined
- May 8, 2011
- Messages
- 75
Hi all, I just installed my TK-790H setup in my new truck, 2013 F-150. Transferred the setup from an 08 Wrangler and had zero issues on that vehicle. Today I was told while on a repeater channel that I have what sounds to be wind noise while TX and an occasional drop off, and a small amount of static on RX. I have the power ran to battery, fused approx 6" off the battery, grounded to a rear seat bolt, antenna is mounted in the roof. I wasn't feeling real confident with this ground and I'm really wondering if that could be the issue. The only thing I have done differently between the vehicles is switch from a 5/8w to a 1/4w antenna.
I plan to change the ground out when I get off work but it's racking my brain in the mean time. Thanks!
