W5KVV
So I picked up a stack of baby kenwoods, 705's & 805's some are "D" models and some are non "D" models.
All are in good working order on their original frequencies. Plan is to disperse them to local hams.
I'm having a heck of a time communicating with these little rigs. I'm using KPG-6D v1.30 on an old slow DOS only computer. I've programmed hundreds of radios on it with no problem. My cable is a generic, but again, no issues on everything from TK-730's to TK-7360's to TKR-750's.
Is there a trick to making these communicate? Programming mode or similar? I get a "cable disconnect" every time I try to read or write a radio. I know these are FPP if certain jumpers are moved around. If the jumpers inside are set for FPP does it null out using KPG?
Any help is appreciated. They will go to good homes.
