Go Back   The RadioReference.com Forums > Amateur Radio > Making Contacts / On the Air
Making Contacts / On the Air - Have a question about getting on the air or how to make a contact? Just want to brag about your latest DX contact or contest score? This is the forum for you.
Old 06-26-2016, 2:44 AM
Default 2 Meter Band Opening!!
Big 2m band opening on the East coast today at 2:30 AM EDT!!
Old 06-26-2016, 8:32 AM
N2AL's Avatar
I tried to CQ this morning while mobile, on my way to headquarters. I was on VHF Call, 146.520 MHz this morning around 0900 Zulu (5 am local) but I was unable to contact anyone. I figure the bands either closed up, or I was the only station monitoring.
Yesterday I was copying stations from Maryville, TN and Cleveland, TN, while mobile around the Knoxville area. They were preparing for Field Day and moving to alternate frequencies to QSO.
Andrew | N2AL
www.n4awl.com
Andrew | N2AL
Nurture your mind with great thought. To believe in the heroic makes heroes. - Benjamin Disraeli
Old 06-26-2016, 8:53 AM
ecps92's Avatar
still looking good at 9am Sunday
VHF Propagation Map
Bill N1KUG
Cruise Ship Frequencies
http://www.scanmaritime.com
Old 06-27-2016, 3:35 AM
Huge 2M band opening East coast 3 AM EDT!!
Old 07-19-2016, 1:40 PM
Weak signal work is mostly SSB (single side band) and around the SSB calling frequency of 144.200 Mhz. Two meters can be open for SSB and other weak signal modes and signals are still not enough to break a squelch or make FM reliable.
It can be worth a try but if you want to go for distance, get a rig that works SSB-you will find a whole new world. Antennas are also usually horizontally polarized rather than the vertical for FM. The path loss trying to work horizontal with a vertical is around 25 db if I remember. Of course, polarization is less a factor once a signal 'bounces'.
73
Old 07-19-2016, 2:16 PM
73
Good points, and a small 2 meter beam can work wonders when the VHF band opens up!
Old 07-19-2016, 6:04 PM
w8prr's Avatar
Although FM, it is interesting how many APRS stations show up when the band opens.
Old 07-19-2016, 6:24 PM
W9BU's Avatar
Lead Wiki Manager
Direct, or hopping through digipeaters?
During certain times of year and certain times of day, you can sit in Indianapolis and see APRS position reports from stations in Michigan. Those reports are hitting a digipeater in southern Michigan which is then heard by a high-profile digipeater in Indianapolis.
Lead Wiki Manager and Forum Moderator.
"The whole world's living in a digital dream. It's not really there, it's all on the screen." -- WB6ACU
