kb2vxa said:
The occupied bandwidth of a standard FM communications channel is 10Khz (deviation +/- 5KHz) and NFM is 5KHz (deviation +/- 2.5KHz).
Yet again, you have taken the time to prove you know much less than you think you know!
Occupied bandwidth includes the amount of the carrier shift, and the significant sidebands.
To put it in simple terms so you are not confused; "You are wrong!"
kb2vxa said:
That's the simple way of stating it, modulation index takes into account deviation, the highest modulating frequency and amplitude.
Why yes, it does, and these are what define the spectral width of the signal. And that provides the true definition between wideband FM and narrowband FM. (Hence where we started.)
kb2vxa said:
N_Jay likes to confuse people with stuff like that even when he himself is confusing bandwidth with channel spacing.
Excuse me?
I provided a clear and correct answer.
You in turn tried to "correct" me with WRONG information, confusing anyone who might not recognize your erroneous crap.
As for channel spacing, it was not brought up, although in Land Mobile communications, channel spacing and occupied bandwidth are often use in a manner as if they were the same.
If you pay attention to teh flow of the thread, you would see that as specific questions are raised, they were addressed in a clear and non-confusing manner. (Right up to when you decided to make a point of your (egotistically though to be) superior knowledge, and proceeded to post incorrect information addressing issues that no one was asking about.
kb2vxa said:
I guess things like that happen when he uses a Wiki instead of FCC/ITU definitions.
No I used WIKI as a reference for others who might want to do some additional study.
I used my BSEE, FCC General Class Radiotelephone License, my 30+ yeas of experience in radio, including FM Broadcast, Land Mobile, Cellular, terrestrial microwave, and amateur as my reference.
You obviously need to go back to my WIKI reference and follow some of the links till you understand everything you think you know.
kb2vxa said:
Hmmm, if you remember the juice commercial on TV could be he needs "the V-8 forehead slap treatment". (;->)
Yes, you do need that!
And here it is for you! (Read my Sig line):twisted:
P.S. If anyone would like to discuss channel spacing and occupied bandwidth, as it applies to the narrowbanding of frequencies below 512 MHz (The current narrowbanding activities), I would suggest so pre-work on emission masks and adjacent channel rejection ratios for various modulation forms (and the complete ignoring of anything Warren tries to add to the conversation).
