K1TSL
I've been trying without success to get my 436HP to receive audio from the hospital's DMR system. I do have the DMR upgrade on the unit, I can hear other local DMR activity. I don't consider myself a DMR novice but obviously I am doing something wrong.
Using the HP software, I've added the Falmouth Hospital channels from the database. It appears to be a one frequency system, CC4 with two channels (one of each time slot). I can hear the radio data stream if I listen to the frequency in analog mode so I know the unit can hear the site.
I used the info in the Uniden DMR wiki to setup a DMR search system specific to the hospital, with a color code search on digital at the frequency I'm hearing the data stream, still nothing.
I added a custom DMR one channel system in the HP software with the Falmouth site frequencies, talk groups, color codes and time slots and still nothing.
Obviously, I am overlooking something here. As I mentioned, I can receive the data stream via analog so I know the scanner can hear it.
Any suggestions?
Any suggestions?
