As a long-time listener to North Reading PD, I've discovered that I can no longer receive any communications. Have they moved to encryption, new frequency, digital?
Have you tried listening with No PL - this would help you determine if they are still on the same freq. They may have gone P25 and if so you will hear a Loud Buzzing noise if you have an older Analog Scanner
I apologize for my delayed response. I figured they went the digital route. I'm going to drop in sometime and check to see if this is permanent. If so, I'll update the info. Thanks again.!
