Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Michigan Radio Discussion Forum
Michigan Radio Discussion Forum - Forum for discussing Radio Information in the State of Michigan.
Closed Thread
Old 01-04-2017, 11:26 PM
RayAir's Avatar
Default MPSCS Sites/Talkgroups 2017
TG 22216
Units doing surveillance in Detroit
DPD and fed RIDs, mostly in the clear:
2829334
2829342
2829354
2829416
2829458
7023165
7026126
7043304
7045880
KXKYC JBSOB XBMZE LCVHV WCW
Old 01-05-2017, 3:11 PM
szron's Avatar
I've had that TG in my notes for few years now. I believe it's a taskforce, VCTF maybe?
Station 20
Old 01-10-2017, 10:04 PM
TG 13346-Logged an RID associated with Morley Fire on Halls Corner & Big Rapids towers. Logged with ARC XT PRO Virtual Control.
Old 01-15-2017, 1:00 PM
Thunderbolt's Avatar
Forums Moderator
This will be the discussion thread for all things relating to the MPSCS TRS in 2017.
MPSCS Wiki:
Michigan's Public Safety Communications System (MPSCS) - The RadioReference Wiki
Database: Michigan Public Safety Communications System (MPSCS)
Michigan's Public Safety Communications System (MPSCS) Trunking System, Statewide, Multi-State - Scanner Frequencies
MPSCS Sites/Talkgroups 2016 (Closed)
http://http://forums.radioreference....ps-2016-a.html
MPSCS Sites/Talkgroups 2014 (Closed)
http://forums.radioreference.com/mic...ps-2014-a.html
MPSCS Sites/Talkgroups 2013 (Closed)
http://forums.radioreference.com/mic...ps-2013-a.html
Year 2012 older threads Pages51-61: http://forums.radioreference.com/mic...closed-51.html
73's
Ron
"A bank is a place where they lend you an umbrella in fair weather and ask for it back when it begins to rain." Robert Frost.
Old 01-17-2017, 10:45 PM
TG 3353-Greenville Police-ENC. This channel was referred to as "442" on Greenville Police primary.
This goes along with a Montcalm County ENC channel, TG 3185, which is referred to as "1-59".
Found on the Stanton tower.
Old 01-21-2017, 9:47 AM
GeneseeCoMI's Avatar
Hearing firefighting comms on TG 12864. Lapeer Co RIDS on Lapeer Co simulcast. Not sure if real or training.
Radios: Pro 106, Pro 96, VX-150, ATS-909X, PL-880, GP5/SSB, SRF-M37W, XML-8110, STR-DH130, RS NWR
Antennas: D130J, RH77CA , DPDP Car Traintenna, WSM-225, RS 200-283, ANT-60, AW 44-US13, AN-100
Old 01-25-2017, 11:30 AM
TG 3932-Ionia County RID 3343157 heard doing a radio check. Heard on the Belding tower.
Old 01-25-2017, 7:35 PM
TG 3111-2 MSP units possibly doing an Accident Investigation, judging from the nature of the conversation.
Heard on the Big Rapids tower.
Old 01-29-2017, 8:31 PM
wx9kvh's Avatar
Are the kent county sites active currently? Im curious because a buddy of mine that lives over there is having problems with programming his scanner to monitor the local MSP district, and he sent me what he had in his scanner and it appears the band plan is blank, my assumption is the scanner doesnt need it, but i thought i may try to put one in there and cant seem to get that right. Any help is appreciated. Thanks.
Equipment Owned :
Motorola Mobiles : APX6500, XTL5000(x2), XTL2500(x2), XPR5550
Motorola Portables : APX8000, XPR7550e
Other Stuff : AT-D868-UV, MD-380, TRX-2
Old 01-29-2017, 8:47 PM
You're correct there. The MPSCS uses a standard plan so scanners don't need custom/multi tables entered to monitor it.
Old 01-30-2017, 3:29 AM
krokus's Avatar
Which scanner is he using?
Sent via Tapatalk
Old 01-30-2017, 12:27 PM
wx9kvh's Avatar
BCD536HP
Equipment Owned :
Old 01-30-2017, 11:46 PM
krokus's Avatar
BCD536HP
All he needs to do is use the software to update, assuming he has the Kent towers selected, in MPSCS. (And talkgroups selected, that are active in the county.)
Sent via Tapatalk
Old 01-31-2017, 10:38 AM
wx9kvh's Avatar
We have done that it's just the reception isn't as solid as an actual radio, it's like it's skipping some information.
Equipment Owned :
Old 01-31-2017, 11:22 AM
krokus's Avatar
Listening to the same tower, with a handheld, next to the 436?
Sent via Tapatalk
Old 01-31-2017, 11:36 AM
wx9kvh's Avatar
Not close enough to wipe out the rx on the scanner. It just seems as if packets of data aren't completely being decoded and or its not tracking the conversation as well as it should. None the less if the band plan isn't an issue then I guess it's a different issue. I was more or less trying to expirament by possibly putting the band plan in but that info seems to be pretty scarce. Thanks for the help.
Equipment Owned :
Old 01-31-2017, 8:03 PM
krokus's Avatar
I was checking if the "real radio" you mention is a mobile/base model, with an external antenna, vice a handheld, like the 436. I want to make sure we are comparing apples to apples.
Old 01-31-2017, 8:04 PM
wx9kvh's Avatar
Nope, it's a friend of his department issued portable. I'm gonna assume it is a XTS2500.
Equipment Owned :
Old 01-31-2017, 10:05 PM
TG 11115-Logged a MMR unit calling the new Mid-Michigan Medical Center-Mount Pleasant.
The new center is the result of a massive expansion of a building which housed doctors offices.
The expansion also includes a 24 hr. Emergency Department, and is in competition with McLaren Central Michigan Hospital, which also just completed an expansion of their own Emergency Department.
Logged on the Mount Pleasant tower, with HP-2E Discovery mode.
Old 02-03-2017, 6:09 PM
RayAir's Avatar
I see we lost Patriot EMS in Genesee County since they recently encrypted all routine TGs.
Anyone who might be in the know, is this going to spread to other EMS TGs in the county, and what prompted this?
Closed Thread
