MFD4305
Does anyone know the planned use of the newly assigned J-events talk groups?
TIA
TIA
My understanding is that the Zone J event talkgroups are (like Zone I) reserved for law enforcement only.
I appreciate the input from all of you. My limited perspective thought there was already a pretty big number of "Interop" channels available on G, H, and I. . . .
+1 on that. My county is guilty of that; they routinely request a G or H talkgroup for the county fair, while SPEV1, SPEV2, SPEV3, 13COM, etc sit idle. That decision is made above and outside of my command chain. I've tried planting the bug in someone's ear to cease that practice, but it continues. Gotta pick your battles... :roll:There are a ton of interop options via the existing EVENT talkgroups. The issue is a lot of agencies use the G-J EVENT talkgroups for local events, etc., that don't even require their use.
Local agencies/counties/entities already have local interop talkgroups built into their template (e.g., ##SPEV1 etc.), and these are designed for local-level interoperability for things like county fairs, races, incidents, festivals, etc., where all the agencies participating or expected to participate are from the local area where the event is taking place. For some reason they still pull EVENT talkgroups from the NCC and frequently pull a lot of them for a single, small event when the county-level interop talkgroups already in their template would do the job just fine.
You are correct. But with the way the system works one TG can only be used in one place at the time. Just because G-Event-1 is only enabled for a search warrant sweep in Detroit it doesn't mean that some up north county can use it for their fair, even thought the TG is enabled only for Detroit Simulcast.
