2017 Thunderbird Freq
Jcoffman412
Gillbert, AZ
Got to listen to the Thunderbirds in Spokane WA last weekend. Only using two frequencies which is great.
Start up + Taxi (All Jets) and Solos freq: 235.25
Diamond: 141.185
Hope you all have a great end of the summer!
Jay
Jcoffman412
Gillbert, AZ
3 days at the show. That's what they used all three days here in Washington. Had originally programmed 141.085 as listed in the air show reference but was only getting white noise on transmissions during Thursday practice.. Switched to 141.185 for Friday-Sunday and the diamond was clear as day. Checked my scanner just to make sure. If you were getting something different, please list it though! The airshow reference was wrong on blue angels too on some frequencies for Seattle. Better to have any new frequencies for others going the rest of the year!!!
Jay
cg
Connecticut
I had them on 141.175 and 235.2500 during practice today. Couple brief transmissions on 413.2750 (NFM) as well.
chris
Slugworth
Westfield, MA.
Easier to step up a custom search 138.000 - 143.975 AM Mode, using 25Khz search step size.
Let us know what you discover...
lol I have no idea what you just said!! I have a PRO 97 scanner and I tried to input the 235.250 and it wouldn't take it. I need to update my scanner!!!! lol
dgregjones
Epsom, New Hampshire
If you're just using the scanner for airshows or NASCAR events I would recommend a BC125AT for about $125. Save yourself some money.
Racescanners.com sells theirs with the audio amplified through the headphone jack which you will need for the races, but if you are just using it for airshows the stock model should work just fine.
Duke
Jcoffman412
Gillbert, AZ
Agreed! The 125 is a great scanner and I got it for under $100 on amazon. Listened to both Thunderbirds, Blue Angels and the Hyrdo race pits with it. I get some EMS stuff too but it does not have p25 which is needed for most police broadcasts these days.
Jay
Xray
125 is a nice little scanner, a necessity for airshows since it covers the military air band.
Low price, nice form factor, easy to program, good battery life, almost a no brainer - Would have been a $1K scanner 10 years ago.
aar9sm
The Pro97 covers mil air
Frequency Coverage: 25-54, 108-136.9875, 137-174, 216.0025-221.9975, 222-225, 225.025-405.975, 406-512, 806-960 (excluding cellular) and 1240-1300MHz
Scan rate 60cps
AM/FM/CTCSS/DCS mode selector
Slugworth
Westfield, MA.
Duke
But this isn't digital correct?? The 436 is the handheld version of the 536 correct? Is there one In between the BC125AT and the BCD436 that's digital? Or would the next upgrade be the 436.
I saw this one as well Whistler WS1040...
dgregjones
Slugworth,
Correct, the BC125 is not digital, and the 436 is the handheld version of the 536. I got a 436 a couple of years ago and paid about $450.
The in between digital model that Uniden manufactures is the BCD325P2. Cost is about $380.
Scanner Master and Ham Radio Outlet have them. You might be able to get a deal on Amazon or eBay.
I hope this helps.
Duke
Slugworth
Westfield, MA.
Slugworth,
I hope this helps.
Duke
Duke thank you for your help!!!
Xray
Found 149.65 [am] today, most active freq of all used during the show.
Xray
BC125AT is a hot little scanner, I use it myself when mobile.
Its downfall is weak audio [not really "weak", can be expected from any handheld], but it can be tough to hear the pilot chatter with jets in the vicinity.
I use a little plug in speaker to boost the audio a bit, ronski had a bluetooth speaker [wired] plugged into his handheld that about drowned out the jets.
I'd like something in between, and something that can be clipped onto a belt and not carried, still searching.
