Attached across several attachments are the AP-1/B Air Refueling Tracks and supporting documents outlining each AR Track, along with Radio Contact Frequencies (UHF Primary and Secondary) and the FAA ARTCC Entry/Exit Center Contact Radio Freq's too.
Find your AR's near your location and often you can hear a AR operation from ~ +100 miles with a good antenna capable pf the 225-400 MHZ range. Naturally, the better the COAX, Connectors and Antenna height the better the reception....
Look up NOTAMS via: https://pilotweb.nas.faa.gov/PilotWeb/
to understand Mil-Air Ops in or near your location by the closest ARTCC(s) to you.
Remember some AR Tracks cross several states/areas and ARTCC Sectors as well.
Also, always check the "Remarks" section, as some nuggets sometimes are included.
Enjoy
Enjoy
