I used to know all this stuff....
When I moved out to Kitsap in 2010 I never reprogrammed my 396T scanner, I just put the local sheriffs dept in the quick-save memories and let it go at that. Going through some stuff I found the activation code for the ARC software and after downloading it, the code still works!
So I decided to go ahead and properly program the scanner. Everything is going well except when I try to program the nearby navy base (where I work). I'm using the information here: https://www.radioreference.com/apps/db/?sid=3856#tgCid-9510
Here's the problem I running up against. For a single talkgroup ID, say Gate Security (ID 23808) there are perfectly clear voice transmissions some of the time, then other times it sounds encrypted. The time between clear and garbled is sometimes only a few seconds. This happens on several different talkgroup IDs. I highly doubt they're constantly switching between encrypted transmissions and unencrypted.
I'm LOS about ten miles from the base, so could it be I don't have enough antenna?
Programmed something incorrectly? (I don't notice any special place in the ARC software to input a control freq, just list all the freqs)
I have the option of driving out to the base and sitting outside the cop shack with the scanner in Close Call until they transmit, to make sure I have all the freqs programmed.
Like I said, I used to know all this stuff but I'm a little rusty!
