From 35,000ft, SC going to get big green snowflakes tonight
spacellamaman
pretty sure this is the most extreme i have seen posted yet. 30 miles and 35000 feet. the time block is prob how long it'll take to get to the ground...
!GNV 12/080 ZJX AIRSPACE PJE WI AN AREA DEFINED AS 30NM RADIUS OF MMT113018
(18NM SE KMMT) SFC-FL350 1812090100-1812090500
and then all next week it seems stuff is going on in SC:
!CARF 12/089 (KZJX A2024/18) ZJX AIRSPACE STNR ALT RESERVATION WI AN AREA
DESCRIBED AS ILM229056 TO ILM200056 TO ILM208123 TO ILM221123 TO POINT OF
ORIGIN. AVOIDANCE ADZ. 8000FT-FL190 DLY 0030-0900 1812110030-1812140900
!CARF 12/088 (KZJX A2023/18) ZJX AIRSPACE STNR ALT RESERVATION WI AN AREA
DESCRIBED AS FLO216034 TO FLO150034 TO FLO159046 TO FLO206046 TO POINT OF
ORIGIN. AVOIDANCE ADZ. 11000FT-FL190 DLY 0030-0900 1812110030-1812140900
!CARF 12/087 (KZJX A2022/18) ZJX AIRSPACE STNR ALT RESERVATION WI AN AREA
DEFINED AS MMT322011 TO MMT040051 TO MMT052055 TO MMT064051 TO MMT142011 TO
POINT OF ORIGIN. MULTIPLE MILITARY ACFT. AVOIDANCE ADVISED. SFC-2500FT DLY
2300-0900 1812102300-1812140900
!CARF 12/086 (KZJX A2021/18) ZJX AIRSPACE STNR ALT RESERVATION WI AREA
DEFINED AS A 5NM RADIUS OF CAE077013 AVOIDANCE ADVISED. SFC-2500FT DLY
2300-0300 1812102300-1812140300
!CARF 12/085 (KZJX A2020/18) ZJX AIRSPACE STNR ALT RESERVATION WI AREA
DEFINED AS A 10NM RADIUS OF CAE219047. AVOIDANCE ADVISED. 7000FT-FL180 DLY
2230-0900 1812102230-1812140900
!CARF 12/084 (KZJX A2019/18) ZJX AIRSPACE STNR ALT RESERVATION WI AREA
DEFINED AS A 6NM RADIUS OF CAE093030. AVOIDANCE ADVISED. 7000FT-FL230 DLY
!CARF 12/083 (KZJX A2018/18) ZJX AIRSPACE STNR ALT RESERVATION WI AREA
DEFINED AS A 11NM RADIUS OF KMMT. AVOIDANCE ADVISED. 7000FT-FL180 DLY 2230
!CARF 12/082 (KZJX A2017/18) ZJX AIRSPACE STNR ALT RESERVATION WI AN AREA
DESCRIBED AS AYS323065 TO AYS351066 TO AYS063026 TO AYS VORTAC TO POINT OF
ORIGIN. AVOIDANCE ADZ. 9000FT-FL190 DLY 2200-0900 1812102200-1812140900
!CARF 12/081 (KZJX A2016/18) ZJX AIRSPACE STNR ALT RESERVATION WI AN AREA
DESCRIBED AS CHS298072 TO CHS 312068 TO CHS331015 TO CHS271022TO POINT OF
ORIGIN. AVOIDANCE ADZ. 13000FT-FL190 DLY 2200-0900 1812102200-1812140900
anyone privy to info?
alcahuete
Antelope Acres, California
Don't know what this particular instance is, but stuff like that happens all the time with HAHO (High Altitude High Opening) jumps. The parachutes are opening at 35,000 ft. and the jumpers are drifting down to the surface. I've actually seen them drift well beyond that, given winds and such.
spacellamaman
never tango with terrain
oh, i see. i bet it was a real sight when they drifted well beyond the surface. i guess its true, the only thing worse than falling is landing.
thanks freqhopping, that's what i was looking for .
noticed today similar NOTAMS posted for the 12th so prob got delayed cause of the weather. anyone in the area ought to keep an eye out, and would be cool if any results reported back here :)
majoco
Stirrer
New Zealand
Air-to-Air and Ground-to-air anti-aircraft fire or training missiles. Air-ground attack, bombing runs - all good fun. I have a bombing range about 15 miles away and it still makes the ground thump!
Ask Lauri - she'll know somebody who knows somebody else who will have a the gen!
