Looking for Fire Pager Tones
KD0DWV
Fridley,MN
I am lokking for Fire department pager tones for Hennepin, anoka and Wright counties if anyone has them or knows where i can find them to program an old pager
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Since our wiki doesn't have them (and I would assume you have already asked on other boards), you're going to need to do some homework. Fortunately no modifications to your scanner are needed, and there are a few free programs that you can use to measure the tones. You can find them linked at the bottom of;
Fire Tone Out - The RadioReference Wiki
best regards..Mike
oem4872
Savage Fire Tones
Does anybody happen to have the tones for Savage Fire ?
mattnelson26
Hopkins, Minnesota
i am sorry but i will post them here tomorrow night or thursday morning. i am also going to try to update wiki. i also got alot of hennepin county fire department tone and duty crew tones i will also post.
thanks,
matt
stmills
Twin Cites Area MN
Wirelessly posted (Mozilla/4.0 (compatible; MSIE 6.0; Windows CE; IEMobile 8.12; MSIEMobile 6.0) Sprint S511)
I am guessing you are using a scanner hioked to a computer running a decode program. What program and does it require anything other than pluging into the sound card?
mattnelson26
Hopkins, Minnesota
here is all i got so far i am going to start work more by just having one of my scanner just on one city.
thanks,
matt
CITY/ STATION # A TONE B TONE
ST. LOUIS PARK FIRE
1 649.9 592
2 650.2 755.2
ALL CLL 650.2 667.5
BOTH 650.2 684.9
MINNETONKA FIRE
DUTY CREW 347.3 646
3
4
5 347.3 581
SAVAGE FIRE
371.4 411.8
BURNSVILLE FIRE
BOTH 2225.7 1156.3
EAGAN FIRE
3 810.1 905.6
4 1393.7 339
5 1393.2 485.1
MED FIRE 411.8 767
STATION 1
ROSEMONT
ALL CLL 979.7 1512
HASTINS FIRE
ALL CALL 566.1 831.2
SHAKOPEE FIRE
944.9 1047
BELLE PLAINE FIRE
411.3 624.8
EDEN PRAIRIE
ALL CALL 538 331.2
STATION 1
STATION 2
STATION 3
STATION 4
LAKEVILLE
1 369 1512
2 392 1511.9
3 412.8 1512.1
4 433 1512.1
MENDOTA HEIGHTS
ALL CALL 1215.9 831.4
SOUTH METRO
ALL CALL 744.2 403.3
APPLE VALLY
STATION 1 952.2 566.4
STATION 2 952.2 599.9
ALL CALL 951 635.4
iNVER GROVE HIGHTS
ALL CALL 368.7 831.2
HAMEL
ALL CALL 384.9 524.8
WEST METRO
STATION 1 1156.3 788.6
STATION 2
STATION 3 1122 670.2
PRIOR LAKE
ALL CALL 505.3 945
FARMINGTON
STATION 1
STATION 2
SAVAGE
ALL CALL 371.4 411.7
JORDEN
ALL CALL 691.7 1047
ELKO/NEW MARKET
ALL CALL 1047 457.6
PLYMOUTH
DUTY CREW 473.8 715.9
STATION 1 347.3 430.4
STATION 2 715.9 715.9 ?
STATION 3 430.3 1286.8
ST. ANTHONY
DUTY CREW 474.4 524.8
BROOKLYN CENTER
DUTY CREW 430.3 524.8
BROOKLYN PARK
DUTY CREW 347.3 384.9
WAYZATA
ALL CALL 347.3 879.6
MAPLE GROVE
STATION 1 384.9 879.6
STATION 2
STATION 3 473.9 879.6
STATION 4 524.9 879.6
STATION 5
CARVER COUNTY HAZMAT
ALL CALL 422.6 524.8
EXCELSIOR
STATION 1 385.2 347.3
STATION 2 384.9 464
ALL CALL 347.3 793.9
MAPLE PLAIN
ALL CALL 793.9 347.3
OSSEO
ALL CALL 384.9 793.9
ROGERS
ALL CALL 793.5 646
MOUND
ALL CALL 384.9 715.9
NEW PRAGUE
ALL CALL 1047 1157.7
JASII
Memory Capacity
This might be a good time to add a link for a standard tone chart http://www.midians.com/pdf/tone_signaling.pdf The reason I point this out is that it might be a good idea to make sure we use standard tones unless we know they are using non-standard tones. For example, the Rosemount Fire tone listed is:
979.7 1512
However, when you look at the chart you realize that Reed Group 3/Tone 6 is actually 979.9 Also, 1512 should be 1513.5 hZ. If I recall correctly, many pagers and other tone alert receivers might have a tolerance of a couple of hertz either side of the actual tone. Thus, a receiver programmed for 1512 would respond to 1513.5 hZ. Again, I just point this out so that people know that there is a standard. Similar to CTCSS, a decoder might display a CTCSS as 100.4 hZ, when it should be 100.0 hZ. So, to look again at Rosemount Fire, it could be listed as:
Tone A 979.9 hZ
Tone B 1513.5 hZ
And for those concerned about timing, the newest Unidens handle that without having to program the timing.
Paging technical information for voice pager users
hamelfire
Hamel MN
Just an fyi all departments at least on the Henn system will be going to a 700 mhz tone system sometime in the near future. My understaning is that only minitor 5 pagers are able to be reprogrammed for this.
