ARCH Air Medical
ZOU4Life
St. Louis
Is the dispatch frequency for ARCH Air Comm STL base 461.52500? What other frequencies does ARCH use and how do they work? Does the dispatch frequency dispatch ARCH like dispatchers do for public safety, or is it just helicopter operations? Thanks!
scanman1958
St. Louis
ARCH air
Also try 462.075 for the Litchfield tower. They use it a lot for comms near Springfield. The basic method is to call the base for the specific copter by phone and as they go airborne the call information is given to them. Also for IL, ARCH sometimes uses IREACH 155.055 for ground contact.
Starcom21
IL /MO/Global DB Adm!n
MetroEast-St Louis
ARCH info / Wiki page
Don't forget to look at the information contained in the RR Wiki. Some of it is old and needs some updating.
http://wiki.radioreference.com/index.php/ARCH_Medical_Helicopter_(US-MO/IL)
Also, if you are on the fringe area of St Louis or Litchfield actual repeaters, you can also listen to the input frequency to hear the helo often much farther out transmitting, than the repeater output (467.xxx opposed to 462.xxx).
If you are interested in such things, also look at AirEvac on the statewide EMS pages (IL/MO) and on the wiki page links from each page.
http://wiki.radioreference.com/index.php/Medical_Helicopters_/_EMS_Agencies_(Area_Wide)_(MO)
http://wiki.radioreference.com/index.php/EMS_/_Ambulance_/_Medical_Helicopters_/_IDPH_(IL)
http://wiki.radioreference.com/index.php/Air_Evac_Lifeteam_(US_Nationwide)
shortbus91
Jerseyville IL
links above do not work
the links do not work...
