Ht1000 install help
jtd97
Bartlett,TN
I have Motorola RSS (I guess) V. 03.02.01. What are the steps to installing it and what drive do I install it to.?Here's some info from the previous owner:
The software is a Motorola software version R03.02.01 Dated June of 96' It was running on VISTA Beta 3.0 OS...
I used it on my UHF radio, but the program does not appear to have a set limit as long as the radio accepts the frequencies. I had another member ask if it works on his 800 Mhz radio.
THANKS!!
KG4INW
Midlothian, VA
You install it wherever you want but it needs to be run in pure DOS only, don't have any instance of Windows running at all. Second, if you run it on anything newer than a Windows 98 machine (booted into DOS of course), you run the risk of bricking the radio.
I have an old Pentium II, Windows 98 machine with a real serial port that I boot into DOS and it works fine with the HT1000 RSS.
Edit: I'm a little confused with the last part of your question. Are you asking if you can go out of band with a particular radio, completely change a radio's band or is different software needed all together for each band?
