HT 1000 AN...and narrow banding
miamimd1
I keep seeing conflicting information in regards to the AN BN model HT1000 's and narrow banding. Batlabs stated that it does indeed narrow band (AN), and referencing the model with Motorola it states "user programmable" for narrow band. However i keep reading that the DN model is the only one capable of narrow band. So what has the experience been with the earlier HT1000 and programming narrow band 12.5khz or less?
KG4INW
Midlothian, VA
All models AN, BN, CN and DN will do the NB deviation (12.5 kHz vs. 25 kHz) but only the DN models are capable of tuning to the "splinter" frequencies (forget the exact resolution right now) that were added to the band plan.
cifd64
Northern Passaic County, NJ
Yes, it will narrowband, BUT, it isnt like the 1250 where each personality canindividually be set. If you narrowband the 1000, everything on that radio will be narrow. That is what was explained to me by /\/\.
miamimd1
That was my understanding, the radio will be set on low power on MURS frequencies anyway and narrow banding is allowed on all frequencies anyway. I picked up a AN in great shape for $25.00 with charger and mike cant wait get it programmed.
KG4INW
Midlothian, VA
No, you set each mode (channel) to whatever you want, narrow, mid (20 kHz) or wide, at least on every 1000 I've seen. Perhaps you're (or whomever you talked to) thinking about some of the Radius portables that were either or.
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
Only the DN's will do the 2.5 Khz steps necessary to program in one of the newer splinter channels, ie. 153.777500. The AN-CN models will do the new 12.5 Khz channel spacing spec, but only for non-splinter frequencies like 155.235000.
In many cases, earlier models will still be very serviceable for many years to come. But when an agency licenses and implements a splinter channel some time in the future, the earlier models won't be programmable to the new frequencies.
KG4INW
Midlothian, VA
Exactly. It does get confusing unless you deal with these sorts of issues on a daily basis! So many variables.
miamimd1
Thanks for the input, and there is indeed almost a science in learning the programming and functionality of the motorola radios.
