Motorola radio battery with four pins?
derota
Itasca County, MN
Sorry if this seems like a stupid question, but could someone point out (if you know) which is negative and which is positive? Also, how many cells are in this battery? This is a battery for a Motorola CP110m
Thanks,
Vinny
jaspence
Michigan
Motorola battery
A little work with a multi-meter should answer the terminal question. For the number of cells, divide the total voltage of the battery by 1.2 (sometimes 1.25, depending on manufacturer) if it is a NiCd or NiMH battery to find your answer. The Motorola battery I have reads 7.5 volts, so it is a 6 cell battery (7.5/1.25=6).
derota
Itasca County, MN
...and If I don't have a multimeter?
jaspence
Michigan
Motorola battery
If you are into radios and electronics, a multi-meter is a must. There are many values that can be tested, and I don't trust any new charger or power supply before I check the output and polarity with my meter. Reverse polarity or overvoltage can cause damage far in excess of the cost of a meter.
