Astro 25 cps - xts2500
BlueDevil
WA
I have a Motorola Online account with access to the programming and CPS software for 2-way radios.
I have a XTS2500 radio that I need to narrowband and I cannot find the right file to download for the ASTRO 25 Family mobiles and portables CPS.
Can anyone direct me to what exact file I need to download? Motorola does a good job at making it difficult to understand and find.
Thanks!
Brandon, K7KLA
FFPM571
Nashvillle
ASTRO25 CPS for portable the latests revision is 17.XX i believe. Its not a file per se. You change settings in the CPS to narrowband the radio.
BlueDevil
WA
Maybe I am missing something or don't have the right access because I don't see a ASTRO25 CPS for Portables of any version
FFPM571
Nashvillle
if you havent filled out the forms for the software agreement your account wont show it
BlueDevil
WA
I have filled out some for the HT series. I suppose I have to fill them out for the ASTRO25 series as well?
ramal121
Lots and lots of watts
Calif Whine Country
If you haven't purchased it or your subscription has run out it will not show in the resource center and obviously you can't download it.
Search RVN4181 in the buying center to see it.
KE4ZNR
Radio Geek
This is what you should come across :)
Marshall KE4ZNR
BlueDevil
WA
I finally found it. It appears they want to charge me for it even though I already have a subscription.
KG4INW
Midlothian, VA
If you only have a subscription for the Professional series, yes you'll have to purchase the Astro25 CPS. Or are you saying you already have a subscription and you're just trying to update the CPS? A subscription is only good for 3 years.
BlueDevil
WA
I purchased the HT series CPS last year and it was my understanding that I had a subscription good for 3 years starting at that time. I am not an expect on this stuff. Maybe I only have a subscription to the HT software since that is what I purchased.
mikewazowski
Staff member
Forums Manager
Oot and Aboot
Do you mean HT as in HT1250/HT750?
That's a completely different software package then the ASTRO25 line and requires a separate subscription.
BlueDevil
WA
I will look for another agency within my county who may have the software. Not going to be able to afford that.
