I have a used GM300 radio for GMRS (I have license).. and the programmer set it for PL tones of 127.3 for 462.625, and 141.3 for the 462.550 channels..
However my other GP350 NON-PL setup radio is able to transmit clearly to the GM300.. it seems like the PL is not working on RX at all..
I can't test the TX PL side as I'd have to flip my (below noted KW 805D around)..
Testing the GP350 with non-PL against my working/good KW 805D with PL setting I get nothing but an indicator/busy picture but no audio thru it, till I take the SQ off then I get the audio.. which is proper..
What could he have missed (if anything) in programming?? He said something about maybe prior signalling settings (that he did not check)??
