The RadioReference.com Forums
-   Motorola Forum (https://forums.radioreference.com/motorola-forum/)
-   -   Cloning Help (https://forums.radioreference.com/motorola-forum/258652-cloning-help.html)
WQOW380 01-22-2013 4:27 PM
Cloning Help
How do I clone my Motorola 6350????
I have programing cables and software
KG4INW 01-23-2013 6:00 AM
I assume you mean XPR6350, in which case you simply click the clone button in CPS and then OK when the serial number window opens. Of course, you can only clone radios with exact matching model numbers and feature sets.
WQOW380 01-23-2013 11:44 AM
Thank you very much for your response. Could you give me a little more detail? I am 74 years old and obviously not certain of what I am doing. LOL
I guess I need two radios, the one I wish to clone and the one I am cloning from. My wife works at a large mall and she is assigned a radio. They gave me another one which had older stuff on it. They are both Motorola MOTOTRBO xpr6350's.
Thank you again.........
KG4INW 01-23-2013 5:58 PM
No problem. Yes, you hook the first one up, read it (click the read button), it's a good idea to save a copy of the codeplug at this point (File -> Save As), make sure everything is programmed how you want it and then hook up the second radio (after detaching the first of course) and then clone.
Again, as long as the two radios have the exact same model number (as read off the tag on the back of the radio under the battery) you should be able to clone. Otherwise, it'll give you an error and you'll have to then program everything by hand.
