MCS 2000 Question
TFC301
Terrebonne Parish, Louisiana
Hello,
Its been a while, I haven't posted on here lol. Anyway, I just purchased a Motorola MCS 2000 VHF remote mount 110w radio. I was wondering if this radio was like the Spectra and NEEDS an Ignition Sense cable for it to power on, transmit, etc.? I've been reading some conflicting articles, some saying it will work without the ignition sense others saying that it won't. So, will the MCS 2000 work without the ignition sense cable?
Thanks.
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
Hello,
Thanks.
There is some info on the MCS2000 family over on batlabs.com and a little bit on repeater-builder.com.
The install and service manuals for these are almost certainly available online somewhere, too.
phillydjdan
Wirelessly posted (Mozilla/5.0 (Linux; U; Android 2.3.5; en-us; ZTE-N910 Build/GRJ90) AppleWebKit/533.1 (KHTML, like Gecko) Version/4.0 Mobile Safari/533.1)
The ignition sense is programmable. If you dont want to use it you dont have to. However, if the previous owner has it enabled, you will need to connect it in order to power the radio for programming. Once you disable it in the CPS you wont need it
cabletech
Puget Sound
If you would like the ablity to use the radio without the key on, then disable the capablity.
If you would rather have the key on then enable it
Bottom line, it is up to you.
N4KVE
PALM BEACH, FLORIDA
One question, since we're on the topic. If I have my radio programmed to not need an ign sense cable, & I turn the radio off, is there still a small draw on the battery. I heard a rumor there was, but if I program the radio to use ign sense, & wire it correctly, when the radio is turned off & the key is off, there is no draw. Can someone confirm this?
N4KVE
PALM BEACH, FLORIDA
But I haven't installed the radio yet, & I don't plan to until I know the answer. This way when I buy the acc connecter, I'll know whether to use the one I have w/o the ign sense lead, or do I buy the one with the lead. So if someone knows the answer, I'd like to know before I drive 30 miles to my storage warehouse to dig out the radio, & drive back another 30 miles.
