Adding 2nd freq. to Minitor V
Cow
Bainbridge, Georgia
I have searched this topic and found a few threads on it, but I just want to be 100% sure before I get into it. We have a guy with our department and he also volunteers at the dept. in the town where he works. He travels back and forth during the day between the two districts and does not want to carry two pagers. His other department gave him a Minitor V with SV and it only has one frequency in it along with that department's tones along with their central department's tone. I have the Minitor V programming software that I downloaded off of the Moto website along with the programming cradle. My question is does the software have to be in engineer mode to add a second frequency? Thanks for answering my questions during the past week.
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
It depends on the exact model of the pager. He may already be carrying a two channel pager. The only way to be sure is to have the model number. Since you have the PPS and cradle, just read the radio. The general info tab will tell you what you need to know.
If it is a one channel model, you will need engineer mode to convert it. That's not for the inexperienced to do the first time.
Cow
Bainbridge, Georgia
I didn't think about that, but the guy who works for Motorola told him that it could not be done...that's when I told our guy that when I get the programming stuff that I could do it, then I remembered that you had to go in engineer mode to do it and I don't know the password... I tried the hack, but I don't know if works because I haven't got my programming stuff yet. I doubt anyone is going to give out the password though...
GTR8000
NY/NJ Database Guy
BEE00
Well, you've got to get the software working before you worry about the programming cradle. Either the hex edit of the PPS worked and you can get into Engineering Mode, or you can't. The programming cradle has no bearing on that.
Cow
Bainbridge, Georgia
I thought that I had to read the codeplug first before I could find out anything...?
SteveC0625
The hack instructions include the password and some info about how to use engineering mode. If you don't have the password and/or the instructions, then whatever you have there is suspect.
Just wait for the pager and your cradle. Read it first and determine if you even need to go further.
com501
If it is indeed a single frequency pager, if it is sent in for service, it will come back as a single channel pager. This of course voids ANY warranty the pager may have, and if it is under service contract, jeopardizes the employee's employment if the employer were to find out that unauthorized changes were made to their property without permission.
Cow
Bainbridge, Georgia
His chief said that it was okay to make the change, so we've got the green light.
HRN
Two things...... First, you have to have a code plug opened before you can make the change from 1 channel to 2 channels. So you do have to wait until you get the programmer. Second, if you send it to the Depot for repair, it will come back with the original serial number and the correct model number. It does not void the warranty and they make the change. I have done this before and sent pagers back that fire companies have done and it has never been questioned or the warranty voided.
