Hi, question for any knowledgeables out there
I am trying to set up a no-transmit no-affiliation setup to monitor a P25 Phase II system to which I do not have WACNK/ASK access. I have successfully followed P25.ca's guide to do this for Phase I systems neighboring/overlapping the system and area I operate in, so it does in principle work.
With Phase II TDMA systems, the APX will scan-stop on the appropriate talkgroup object when that talkgroup is active on the system, so it appears to know that a channel grant has been assigned for that talkgroup. However, the APX will only give a slight speaker pop when it locks on, and will not output received audio (if it indeed does receive it) to the speaker.
System is set as follows: coverage type disabled (only one site loaded)
WACN ID set,
no system ID set (no ASK/WACNK access)
no RFSS/site IDs set
Control channels for that site only entered
700mhz FDMA (6.25kHz) and TDMA (12.5kHz) +30 split 'channel ID's entered, plus 800mhz FDMA -45 split 6.25kHz.
NOT set as X2 voice capable (full Phase II system)
Set as Phase 2 voice capable.
Modulation set to C4FM (tried CQPSK also for the hell of it)
Is there anyone who can aid me in debugging why it will not break squelch / output voice for TDMA transmissions when it will correctly do so for FDMA systems? Barring that, is there anyone who has a successful codeplug for Phase II TDMA monitoring that I can receive and browse through for info? Please ask here or PM if you need further codeplug info.
BTW, the radio IS flashed QA00580 for TDMA ops, as well as H38 Smartzone, Q806 ASTRO digital, Q173 Omnilink, Q361 P25 9600baud, and the ones necessary for 700/800 operation.
WACN ID set,
