Motorola CDM1550 (AAM258HF9DP5AN)
W1CRN
Liberty, SC
Does this model encode the QuickCall 2 tones? From what I have found on /\/\ website its says all the CDM1550's does encode the QCII tones.
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
Double check your model number. The 8 is incorrect. It's likely an S which makes it a 450-512 MHz model.
The DP makes it a PassPort/LTR radio and the last 5 makes a 128 channel model.
AKAIK, it should be able to encode QC-II, but I'd have to look at a codeplug to be sure.
W1CRN
Liberty, SC
ok it is and S sorry about that. and here is another one (AAM25RKF9DU5AN). I am trying to help a buddy of mine and the radio is not in front of me so I don't have a codeplug for it. I am going to have him send it to me so I can look. I have a the software but don't want big /\/\ coming after me if i give it out.....lol
SteveC0625
R split is 403-470. DU is LTR, and the 5 is still 128 channels. Should also do QC-II, but again, have to read the radio to verify.
SteveC0625
Huh, that's odd. We use CDM-1250's at work and specifically have them in the fire station for alerting, using QCII decode.
The 1250's do just fine. I have one in my truck and we have one in our ambulance base. All of the FD's in our county have them for bases and mobiles. They will all do QC-II Call and Signalling.
Some of the 1550's do and some don't. The OP mentioned two of them by model number; one is LTR and the other is PassPort/LTR. When I looked in the codeplugs for both models that he listed, there is no QC-II at all, call or signalling.
There are models of the 1550's that will do QC-II. We have three of them in our ambulance
phillydjdan
Wirelessly posted (Mozilla/5.0 (Linux; Android 4.0.4; LG-MS870 Build/IMM76L) AppleWebKit/535.19 (KHTML, like Gecko) Chrome/18.0.1025.166 Mobile Safari/535.19)
The difference is that the ltr/passport radios wont do it, the non-ltr/passport radios will. Its like trim levels in a car. The es model has 6 airbags while the s model has 2. Hope that helped!
SteveC0625
It's even more complex than that. Some of the LTR/PassPort models don't do QC-II and others will. We have three of these and they do it just fine: AAM25KKF9DP6AN
I looked in the sample codeplugs, and I think the 6 vs the 5 after the DP or DU tells which is which. Both of the OP's mentioned radios were 5, one a DP and the other a DU.
Interestingly, even the model number chart in the service manual doesn't say anything about things like QC-II. I'm trying to find something that breaks the model number down a lot more precisely.
