xcharger95x
I am currently having an issue where i get the following on-screen error:
"Couldn't open port. Check weather device/RIB are powered on or not, and the device to RIB, and RIB to PC connection is ok."
Where i did in fact have the 1250 on, i was trying multiple com ports (1,2) which I'm using a ToughBook (XP) where this CPS has no problems, even after re-installing, still no luck.
I've tried to use the USB connector to the front-end of the Mobile and as well as the Ribless connector.
If someone could help me out what to do on this issue, thanks in advance!
