Motorola Forum -
For general discussion of Motorola land mobile radio equipment and their trunking technologies.
07-15-2015, 8:59 AM
MTS 2000 Belt Clip Broke
Hey,
Yesterday I had the Belt Clip part snapped off the battery and broke the plastic that holds the belt clip. what are my options.
Pro-91 Analog, MTS 2000 800MHz, Motorola Astro Saber VHF, APX 6000 7/800MHz, XPR 3300 UHF, XPR 6550 UHF
07-15-2015, 9:30 AM
Do you have all the parts? if so get some ( J&B weld) it comes in a packet of 2 tubes @ walmart & con be use on plastic. follow directions & put your belt clip back together.
07-15-2015, 9:30 AM
Slide the radio in your back pocket, or glue the belt clip to the battery.
FORMERLY MOONBOOTS
07-15-2015, 9:32 AM
By all the parts. do you mean the little pieces of plastic?
07-15-2015, 9:33 AM
I don't really want to buy a new battery for it so I think I might have to do that
07-15-2015, 9:43 AM
Depending on the brand of battery you may be able to take the shell off and glue another one on it. I had some junk batteries laying around and was bored and did it once. I noticed the name brand ones are hard to open but the cheapo ones will crack. If you have an interstate battery salesman near you a new battery may be cheaper than you think. The one for my firehouse hooked me up with an interstate brand battery for less than the cheap ones on ebay.
07-15-2015, 9:48 AM
They are right down the road from me. Ill take a drive down to them and see what they can do. Thanks
07-15-2015, 10:09 AM
Sticky topic
Not real familiar with that radio, so I don't know if my suggestion interferes with charging
But if it's a good battery, I'd just superglue a clip to the battery.
Buying a second clip to use with other batteries you may have is going to be much cheaper than buying another battery.
Me personally I'd go this route before I did surgery on a good battery.
07-15-2015, 12:20 PM
You could carry the radio in a holster.
Sent via Tapatalk
07-20-2015, 10:29 PM
Not sure if I would suggest using superglue or JB Weld.
If the superglue/JB Weld lets go while you have the radio clipped to your belt or pocket or whatever, the whole radio falls to the ground which could obviously do some damage.
07-24-2015, 10:13 PM
I have portaclips available, feel free to message me if interested. cheaper than 24 bucks, fyi. Can post to my ebay if preferred.
07-25-2015, 8:09 AM
buy a new battery. The cheap ones do that all the time
Thread Tools |
Display Modes |
