HT1250 current firmware version vs. CPS version
swight
I'm about ready to program an HT1250 that I recently bought, however I'd like to clarify one thing before I start. I bought the radio and the seller sent me a printout with the most current radio information that he had indicating the firmware version, original/latest codeplug version, programming dates etc... The printout states that the radio has firmware version R05.18.01. The CPS version that I have is R06.12.05. I want to make sure that attempting to program my radio with what seems to be a large gap in CPS versions won't brick my radio. I've attempted to find the answer through multiple searches however I've had no luck. Also, please excuse my lack of knowledge on the subject. Thanks
N1GTL
CT
Current CPS is R06.12.19. Current firmware is R05.18.01
It won't brick your radio but it may not work at all if it was already programmed with the newest CPS. Also, if you are planning on ham radio use, you need a 25khz entitlement enables in the CPS or it will only let you program narrowband.
Also, no more updates in firmware or CPS should be coming as the radio is discontinued.
Golay
Write your own
A Waris radio with a newer CPS will let you write an older CPS codeplug to it. Once you do that, then that's the CPS version in the radio.
To the OP, my advice is to just stay with the CPS and firmware that is working. It's just an analog radio and imho an upgrade gets you nothing really.
swight
Thanks everyone who replied. I ended up using R06.12.09 and it worked perfectly
