KD9AYZ
Hi everyone,
I may not be posting this in the correct threat (I apologize if so), but I am looking for some advice. I just recently purchased a Motorola XTS 3000 off of eBay. I am trying to program it and I am running into a few problems.
My first problem is, there is a local P25 repeater where I live. It is a UHF mixed mode repeater capable of analog and P25 voice. I can get the radio to work just fine on analog with the repeater, however I can't seem to get it to work with the P25. I've checked, double checked, and triple checked that I have the Rx frequency, Tx frequency, PL codes, and NAC all entered correctly. The Rx is set to Mixed mode and the Tx is set to ASTRO. I can hear the P25 noise on the input frequency when I transmit but its not making it to the output of the repeater. At this point, I am not sure if this is a programming error on my side, or something I'm missing that's causing the repeater not to allow my traffic through.
My second problem is that when I'm transmitting on analog I have gotten reports that there is a high pitched humming noise that is present when I transmit. It doesn't go away or change pitch the entire time I am keyed up. I have turned a second radio on to listen and have noticed the same thing. Just a single pitched humming noise that is there the whole time I am keyed up. If the power to the radio is on and I pull the battery and put it back in the noise is 100% gone. As soon as I use the knob to power the radio off and back on again the noise returns. I have also noticed that this noise is present when attempting to use the P25 as well, so I'm not sure if its possible that this is causing interference with the repeater?
My third and final problem, is when I got the radio the battery appeared to be dead. I left it on the charger overnight and the next morning it was still giving me the low battery chirp when I tried to transmit. I ordered a new Impres charger as well as a new Impres battery with date code 1609 on it. I put the old battery on the Impres charger and it went through the entire reconditioning and charging process. No change. I was still getting the low battery chirp. I took the new battery and let it go through the initialization and charging process, this time I was no longer getting the low battery chirp. I thought the problem there was solved but am now noticing that after an hour or two of leaving the radio on I am getting the low battery chirp again. If I pull the battery and put it back on again (without charging it) the radio goes back to normal and I don't start getting the low battery chirp again for another 1 to 2 hours.
I am completely baffled at this point and am not sure how to proceed with this radio. I know this is a lengthy post and I am very grateful for any assistance anyone is willing to offer. At this point, I'm not sure where to even begin with this radio, or if it's even worth my time.
Thank you in advance for any help that anyone is willing to offer
Michael - KD9AYZ
Michael - KD9AYZ
