Motorola Maxtrac Out of band Help
marksroberson
Florida Panhandle
I have recently purchased a Motorola Maxtrac UHF (449.0 - 470.0 MHz) radio that has already had the VCO and the RX coils tuned down to 440, I am using the Motorola RSS Version R07.02.00a and when I add a channel it defaults as 446.0 but I can not tune below the default 449.00 range. I even try the shift key method and it still says "This frequency is invalid" in the top right. do I have to do something in HEX editor or am I missing something in RSS? Any help would be nice
petnrdx
Hudson, FL
If you have the correct RSS, then the shift method should work.
Remember that you must SHIFT all the characters except the . (the period) then re-shift for all the following 0's (zeros)
So 442.55000 would be SHIFT $$@ then unshift for the period, then reshift for %%))) and it should work.
If you are using a LAB version then the shift method won't work.
marksroberson
Florida Panhandle
Thanks for the help! I think I forgot to completely enter the zeros at the end of the frequency with the shift mod. I also changed the Maxtrac.MDF files's band limits.
