I just programmed an XPR6550 UHF1 using the latest version of CPS (13). The software would not allow for the programming of 25 kHz analog. I've read that I can get an EID from Motorola to allow this, but that info was from 2012. Is this still the case? Also, I set scan groups and a scan button on the radio, However, scan does not appear to function using the assigned scan button nor by the menu. When I choose scan form the menu and press OK, nothing happens. Anyone have advice for these issues? Thanks in advance!
