R1225 Channel Display shows FF
jm32935
Kemp, Texas
While making a few changes to my R1225 Repeater using the RSS software my display changed to FF on the radio when I wrote the changes to it.
Now I cannot get the radio to display channel numbers!!!!
Could it be a code plug issue?
Any help would be appreciated.
Slightly different model, but give this a try:
http://www.repeater-builder.com/motorola/sm50/sm50.html
"SM120 Displays "FF":
After a programming session, the radio displays "FF" and it won't transmit at all. Cycling the power or rewriting the code plug doesn't fix a thing.
Apparently the "FF" indicates the radio did not exit programming mode properly. If you hold the '+' and '-' keys at the same time for three seconds, this seems to cause the radio to exit programming mode."
jm32935
Kemp, Texas
R1225 FF in display
The keys on the 1225 are up and down arrows. I hit both and it did not clear the FF.
toolman60
mr762443,
sounds like a code plug problem. If you have a good known working code plug try to clone it back into that radio.
cmdrwill
So Cali
You DID Save the original 'code plug'. You ALWAYS READ the radio first, save a copy of the cp, THEN make changes.
